Question What Power supply ?
Feb 7, 2025
I must take what low cost psu for :
Intel Core i7-2700k,
AMD HD 7450,
2*8GB Ram DDR3,
SSD 500GB
I want can upgrade (like put an GTX 1050 Ti
Look for something like a Corsair 650W or equivalent for that build.
If you want to upgrade to more power hungry equipment a good brand name 850W. That is overkill for your described build though.
Don’t cheap out on the PSU, a bad one failing can destroy the rest of your hardware and data.
Reactions: littlepony
The only problems with 300W are finding a name brand manufacturer who supplies the 300W psus and finding parts. I found one made by Be quiet and it isn’t ATX. Price wise there is £30 difference.
For an extra £30 a more powerful gpu than the 1050 can be accommodated with confidence.
650W supplied my 2700x and a R9 390 with ease for a number of years.
