D
Deleted member 2720853
Guest
My case is a be quiet! Pure Base 500DX. It's great for airflow, mesh front, no obstacles in front of intakes, only the dust filter and the mesh front itself. I have four Pure Wings 2 fans set up like this:
My fans are idling at 850-900 RPM, however after some difficulties they recently started making an odd humming noise.
If I keep my case fans under 700 RPM at all times, they don't make that noise. If I keep them like that at all times, or at least while idle, will it be a problem? Should I set them to ramp up only when the GPU gets hot (which is currently the hottest component in my build)?
Any advice on how to reduce this humming noise? My motherboard ia GIGABYTE Z390 Aorus Pro if you have any tips on how to configure it.
