The fx at 4.6GHz to 5.0GHz will not pull 250w, 200-225 at best. The gpu will not pull 200w either, not even close. It's 120w for reference design, the FTW is maxed out at 150w and even if you could bump over that level, you'd still only get @170w tops.
So 200w for cpu OC + 170w for gpu OC = 370w. That's a lot more realistic figure than the 450w you are imagining. However, you'll never get both to 100%. Even running torture tests, you'll be lucky to get 1 to 100%, the other will throttle @50%.
As I said, try it yourself. Grab msi kombuster and run any of the more intense graphics tests, the fuzzy donut doesn't even do 100%gpu. Then try and run Prime95 small fft. Watch fps go in the toilet. If it doesn't crash the pc.
Just because a cpu is weak means nothing, it still processes graphics code the same, just slower. Doesn't mean usage will change. That's entirely dependent on the game code and threads used and to what extent. I've seen gta:V drive i5-7600k to 100% usage, i7-3770 sits around 55%. Gpu around 30% on the i5 and 60% on the i7. The i5 7600k is not a weak cpu at all, yet it got throttled hard due to 100% loads. No way you'll ever see any game run cpu at 100%, gpu at 100% simultaneously. So forget about theoretical max wattage of both as it'll never happen. 70% of both is about all you'll ever get, whether that's 100% cpu/50% gpu or 50% cpu/100% gpu or any other combination. So with all that OC wattage adding upto @370w, expect at most you'll be actually using @70% of that max, at best. In other words @280w. Not 450w.
