[SOLVED] What specs do I need to run Minecraft rtx at maximum settings?
nicholaslovell
59
Hello, surprisingly I couldn't find much detail elsewhere on this. I'm going to build a new computer and Minecraft is the only game I play. Does anyone have experience or can tell me what specs I need for maximum settings? Specifically looking for speeds and quantity instead of actual make/model of gpu, CPU, etc. Thanks!
First
Minecraft rtx is only on the bedrock edition, and you probably play java edition.
second
nothing can run it at max settings.
If you mean max render distance.
Literally impossible.
the best gpu would be a quadro rtx 8000, then rtx titan, then 2080 ti (obviously.)
but i believe non of those would get over 60 fps in max render distance.
First
second
