G g335 Distinguished Oct 14, 2008 1,108 0 19,280 Feb 19, 2015 #1 Hello What speed and timing DDR4 ram should I get for a i7 5820k? I will use the computer for gaming, graphic design, 3D design and rendering and video editing. Looking for something not too expensive.
Solution faalin Feb 19, 2015 I would get these http://www.newegg.com/Product/Product.aspx?Item=N82E16820226660 the higher speeds will help with rendering and only being 2 sticks you can add more ram to your build if you need to.
faalin Illustrious Feb 22, 2012 6,061 391 41,240 Feb 19, 2015 Solution #2 I would get these http://www.newegg.com/Product/Product.aspx?Item=N82E16820226660 the higher speeds will help with rendering and only being 2 sticks you can add more ram to your build if you need to. Upvote 0 Downvote Solution
