Recently, I got a new mobo, CPU and RAM. Running all good and perfectly and thought I would just check on the specs of my components on CPU Z.
On the memory tab is shows its running at 1496mhz, is this per module or not?
Made sure it was running at 3000mhz on the bios before doing this anyways and task manager recognises it at 3000mhz.
I also checked on the Ryzen overclocking tool and it too shows that it is running at 1500mhz, if this is true how do I set it to run at the correct speed
Specs:
Ryzen 5 2600
Gigabyte GA-B350 Gaming 3
Corsair 2x8gb DDR4 3000Mhz
Specs:
Ryzen 5 2600
