What system is better? Help
Swatting
114
Thanks for anyone helping. Also in the second one I'll prob get a 760 or 770
First pc:
Spec :-
Case : Galaxy Evolution Tower Case With Switchable Red or Blue Led
Power Supply : 500 Watt With Power Cable Supplied
Motherboard : Gigabyte 78LMT-USB3
CPU : AMD FX 6300 Six Core CPU (turbo 4.1Ghz)
Hard Drive : 1tb Sata Hard Drive
Memory : 8gb DDR3 1600mhz Corsair Vengeance Memory
Graphics Card : Geforce GTX 750 1gb (sreen support for DVI / HDMI / VGA connection)
Optical Drive : 24x Dual Layer DVD Writer
Warranty : 12 Months Return To Base (Parts & Labour)
Connections : 6 x USB 2.0 / 2 x USB 3.0 / LAN / Sound
Software : Windows 8 Home 64 bit
Second pc:
Amd FX6100 processor 3.30 ghz plus hyper 212 EVO CPU cooler
Xfx radeon r7770 ghost series
23 inch LG 3d LED monitor
16gb corsair vengeance 16gb ddr3 ram
3tb caviar green hdd
250gb Samsung 840 series ssd
Ocz zs series 750w psu
Asrock 970 de3/u3s3
Dvd player plus extra dvd r/rw drive
Comes with windows 7 64bit home premium.
Microsoft wireless Xbox usb accessory for gaming.
Microphone.
Wireless mouse
keyboard
wired mouse
Yes, a 770 should fit in that case
In first build change your mobo to 900 series, something 990 or 970 will be the best (990 is faster). On these series with a good cooler you can do a serious overclock.
About the graphics card... If you intend a lot of gaming this 750 will strugle, at least get a 750 ti or put some more money into it and buy R9 270X.
But yes the 1st one is better.
P.S. These are just suggestions so research it a bit more.
Everyone, I'm going to get the second one, I'll be replacing the CPU and GPU on August 14 with a eight core @4.7 and a gtx 770
Would it fit this case?
NZXT Source 210 Elite Mid Tower Black
Thank you !
