C cpr05 Reputable Oct 17, 2014 45 0 4,530 Oct 18, 2014 #1 Here is the monitor: http://www.walmart.com/msharbor/ip/23787606?action=product_interest&action_type=title&placement_id=irs_bottom&strategy=TIC&visitor_id=93490262010&category=0%253A3944%253A3951%253A110915&client_guid=e2b1baa0-2090-428b-9985-b437671eba42&config_id=2&parent_item_id=24198206&guid=44abb17f-32ac-470c-9d7c-9dec9cc32455&bucket_id=irsbucketdefault&findingMethod=p13n Thanks Cameron
Solution k1114 Oct 18, 2014 It's dl dvi-d like pretty much every monitor. But dl or sl cable won't matter.
K kapitalistas Honorable Feb 10, 2014 2,732 0 13,460 Oct 18, 2014 #2 https://www.google.com/search?hl=en&site=imghp&tbm=isch&source=hp&biw=929&bih=931&q=dvi+versions&oq=dvi+versions&gs_l=img.12..0.2128.11692.0.13703.14.6.1.7.8.0.61.332.6.6.0....0...1ac.1.56.img..1.13.345.YkvVHO02a_w which version is yours on your monitor. Upvote 0 Downvote
k1114 Titan May 2, 2010 14,240 93 75,540 Oct 18, 2014 Solution #3 It's dl dvi-d like pretty much every monitor. But dl or sl cable won't matter. Upvote 0 Downvote Solution
C cpr05 Reputable Oct 17, 2014 45 0 4,530 Oct 18, 2014 #4 So can you list me a cheap cable Upvote 0 Downvote
k1114 Titan May 2, 2010 14,240 93 75,540 Oct 18, 2014 #5 http://www.monoprice.com/Product?c_id=102&cp_id=10209&cs_id=1020902&p_id=2408&seq=1&format=2 There is no good or bad cables, just go look for whatever cheapest dvi-d cable you can find. Upvote 0 Downvote
K kapitalistas Honorable Feb 10, 2014 2,732 0 13,460 Oct 18, 2014 #6 i guess you dont have that monitor yet. Upvote 0 Downvote
