What type of TV? Plasma vs LED
unknownxxvii
85
I am going to buy either a 55in LED or a 60in plasma TV from either Samsung or LG to replace my 30in Samsung HDTV. I wanted to know which type of TV is better for gaming based on response time and picture quality: sharpness, clarity, rich colors, and deep blacks. All four TVs cost about the same within a $20 margin, so if plasmas are equal or a little better I rather have 5 more inches for the same price. Finally which TV would last longer, and be more reliable? Would I need anymore than 4x AA for TVs this large? Thanks for the help, as I am thinking that I will purchase one no later then the end of Easter.
Possible Contenders:
60" Plasma
http://www.samsclub.com/sams/60-lg-1080p-600hz-plasma-hdtv/prod6480269.ip?navAction=
55" LED
http://www.samsclub.com/sams/55-120hz-led-tv-1080p-2-hdmi/prod7870081.ip?navAction=
Meh, I prefer my JVC DLA. When you start talking about 80" and $4000, it's better just to step up and go 100"+. Nothing like going to the theater in your basement. 😀
Most people buying that kind of TV have dedicated surround sound systems. Sound bars are pretty cheap nowadays, too. A decent ($100) sound bar is excellent. That said, my Panasonic has pretty great sound, better than I expected (I think mounting on a wall makes it better).
One thing to check for is if you can add a Soundbar and have it turn on/off and control the volume all through your normal TV remote. I don't know how many HDTV's support this and what soundbar's are compatible.
I tried to upgrade my dad's audio but he has no interest in an extra remote (I don't blame him).
Either he's happy with the sound he has, or all you have to do is hook up a sound bar and he'll be ok with the new remote (ie, once he here's the difference he'll learn to handle the new remote), or he could simply get a universal remote 😀
...The resolution affects lag...not the screen size. That's like using a projector and saying the amount of lag depends on how big the wall is.
