What types of cases will fit a HP z400 6-DIMM motherboard?
13
Hi, I have an HP z400 6-DIMM slot computer. This is the last version of the z400 they have made. I'm turning it into a gaming PC currently. The case looks to simple and plain and doesn't really have any design into it. The power supply is the same (will post pictures below). I'm wanting to transfer EVERYTHING over to a new case. This includes the motherboard, storage drives, PSU and CD drives. (Floppy disk drive will NOT be transferred over). ALSO this supports liquid cooling I wold like that to fit also. A link to a colling will be posted below. Thanks!
Motherboard: http://
PSU: http://
Liquid Cooling: http://
https://www.moddiy.com/products/ATX-to-HP-Z400-24%252dPin-Non%252dStandard-ATX-Pinout-Main-Power-Adapter-Cable.html
You can buy this and use standard ATX PSU or if you don't want to spend 15$, you can rewire the connector wires on the PSU. There are many guides on this online, just google it and yes, it has worked for many and I haven't heard of a case where it has failed.
There was also one on Ali Express for 10$, but I am unable to find it for the moment.
