Question What Wattage PSU for i9 12900K and RTX 3070Ti?
That should be alright. 290W GPU and the CPU can top out around 250W.
Motherboard includes a wireless card, so your additional one is redundant.
Do you need 10Gbps network? Is there anything else on your network that fast?
I would skip the 250 GB SSD. If you want the OS on a fast drive, you should get a 512GB PCIe 4.0 drive like the 980 Pro, the 970 Evo Plus is PCIe 3.0. (Not that it will make a huge difference, but you might as well if you are going that route)
I also think a 360mm radiator would not be a bad idea for the CPU.
A high quality 850w, at minimum. RTX 3000 has terrible power spikes, so you want a good buffer. A 12900k should be in a Z690 board. Also, I would argue that the 12900k is not worth the added cost, for those extra E cores, vs a 12700k. 240mm AIO is not enough for a 12900k either. Could you please export the pcpp build link? It's easier to come up with a better solution that way.
Reactions: Why_Me
You want to go with a single 2TB M.2 SSD with the B660 boards seeing how that chipset only has 12 PCIe lanes and it's going to gimp a second M.2 SSD. The 12900K is an expensive heat producing power hog that's meant for a Z690 board with decent VRM's. You don't need a WiFi adapter for a board that already has built in WiFi and most all cpu coolers come with thermal paste so you can drop both of those from your build. btw 64GB for a gaming build is a bit insane. You went too high on your board + cpu + RAM and you skimped on your case and monitor. btw you want a G-Sync compatible monitor so that you can take advantage of Nvidia DLSS and Reflex. I would look at these changes to that build.
https://www.cclonline.com/lancool-i...mesh-performance-mid-tower-gaming-case-black/
Lian Li Lancool II Mesh Performance Mid Tower Case £88.03
https://www.amazon.co.uk/dp/B09NTNCGMV
MSI MAG B660M MORTAR WIFI DDR4 £151.98
https://www.msi.com/Motherboard/MAG-B660M-MORTAR-WIFI-DDR4
https://www.amazon.co.uk/dp/B09MDHZ2YQ
Intel Core i7-12700F £316.99
https://ark.intel.com/content/www/u...2700f-processor-25m-cache-up-to-4-90-ghz.html
https://computerorbit.com/products/deepcool-ak620-high-performance-cooler
DeepCool AK620 CPU COOLER £55.00
https://www.tomshardware.com/reviews/deepcool-ak620-review
https://global.deepcool.com/product...-High-Performance-CPU-Cooler/2021/13067.shtml
https://www.box.co.uk/CMK32GX4M2D3600C18-Corsair-Vengeance-LPX-32GB-2x-16GB-3600M_2961063.html
Corsair Vengeance LPX DDR4 32GB 3600MHz (2x16GB) CL18 £116.99
https://www.scan.co.uk/products/windows-11-home-edition-64-bit-english-international-usb
Microsoft Windows 11 Home Edition 64-bit USB - English £111.49
https://www.overclockers.co.uk/msi-...een-led-backlit-gaming-monitor-mo-00y-ms.html
MSI OPTIX 27" G273QF 2560x1440 IPS 165Hz 1ms FreeSync/G-Sync Widescreen LED Backlit Gaming Monitor £248.99
https://www.msi.com/Monitor/Optix-G273QF
https://www.nvidia.com/en-us/geforce/technologies/dlss/
i7 12700 / 12700F gaming benchmarks.
