N napalmgrenade Reputable Apr 3, 2014 15 0 4,510 Apr 12, 2014 #1 I have a coolermaster Hyper 212 evo and I installed the heat sink, now I just have to clip on the fan. I have a picture, http://imgur.com/rAAcrhn Should the fan be on the left or right of the heat sink?
Solution Someone Somewhere Apr 12, 2014 Usually fans have an arrow printed on the side - that's what way the air will go.
Someone Somewhere Titan Sep 23, 2012 22,291 8 84,965 Apr 12, 2014 #2 Normally on the right, blowing air to the left. Upvote 0 Downvote
N napalmgrenade Reputable Apr 3, 2014 15 0 4,510 Apr 12, 2014 #3 So would http://imgur.com/2JEZcQw be the correct orientation? The fan seems to be blowing air into my hardrives/ssd though so im not sure. Upvote 0 Downvote
Someone Somewhere Titan Sep 23, 2012 22,291 8 84,965 Apr 12, 2014 Solution #4 Usually fans have an arrow printed on the side - that's what way the air will go. Upvote 0 Downvote Solution
