Electricity follows strange pathways.Im just curious if what will be the one who'll die first.
Yes, I'm planning on buying power surge protection. Before, my motherboard has blown transistor in it so I returned it to repair, so now I'm curious if my PSU is affected too that's why I am asking if is possible that my PSU died first before the motherboard😊Why not consider a device to help protect against the surges rather than find out?
What is causing this issue?
The blown transistor is near in the front panel port of the motherboard so I think GPU is safe.Yes I think 50% chance I'll RMA PSU and RAM they have 2years warrantyFirst thought was maybe motherboard but now thinking it could be either. Understand your thoughts my gpu just died and took me buying extra psu and ram to sort it out. Surge protector money well spent![]()
And in my personal case last year, totally irrelevant.Most, if not all AVRs, UPSs, and reputable power strips have this basic protection as long as it is properly Earthed/grounded.
Ooh Thank you for the knowledge now I know, Buying an power surge protection extension will solve this problem right?, in that extension I will connect all my components(including other devices like printer)And in my personal case last year, totally irrelevant.
2x HDMI ports on a Denon receiver
1x ethernet port on my main PC
1x ethernet port on my printer.
All devices protected by good quality TrippLite and CyberPower UPS.
PC and printer separated by 2x switches and a router.
The wall plug is NOT the only entranceway.
Surge protection in most devices is only 'good' for one strike at rated protection level and then it's not reliable at all.....
"Help", not "solve".Ooh Thank you for the knowledge now I know, Buying an power surge protection extension will solve this problem right?, in that extension I will connect all my components(including other devices like printer)
Now that you say that I think I'll buy expensive AVR,"Help", not "solve".
Electricity will do what it pleases.
But almost everything electronic you have at home, they're all more or less, connected to an outlet and in fact, can pass current from one device to another through Ethernet, USB, audio inputs/outputs, etc. So for the most part, the main source of surges will be via the outlets.The wall plug is NOT the only entranceway.
And for the Twilight Zone moment from that nearby lightning strike....But almost everything electronic you have at home, they're all more or less, connected to an outlet and in fact, can pass current from one device to another through Ethernet, USB, audio inputs/outputs, etc. So for the most part, the main source of surges will be via the outlets.
To your point, there's also cable TV/internet, external antennas, sat dishes, DSL, everything that is conductive and is exposed, these are also possible ingress points for surge. Most equipment can deal with typically small surges but would likely not survive a direct or nearby lightning strikes, surge suppressor or not. YMWV.
