What will happen if my monitor is 60hz but the game is going at 90hz?
Spexel
Commendable
Feb 6, 2017
31
What will happen if my monitor is 60hz but the game is going at 90hz? Will it skip frames or something? I don't know but i heard about this and im not sure if it was true or not.
You will most likely get screen tearing.
For example:
I see, and what fps does V-sync cap the game at? Also when should I upgrade from a gtx 1070? (with and without overclocking)
My preferences are 75fps at 1080p. How long do you think?
Also when i turn v-sync on will the fps count the monitor fps or the fps that the gpu is exerting? For example, if I turn vysnc on for a monitor that has 75hz, will the fps counter never go above 75?
Considering the GTX 1070 can handle 1440p quite well, you'll have a few years.
But then again graphical fidelity can exponentially jump in the next year or two that will even make the GTX 1070 sweat.
This is a very difficult question to answer without having a crystal ball to tell the future.
The GPU will only render at 75 frames per second.
Thank you.
