what's a good mini-itx tower for water cooling
goldman919
31
i'd like to build a watercooled mini-itx that i can take to lans, I'm an experienced builder but have no experience in with mini-itx builds. Could someone recommend an easy to carry mini-itx case that has space for radiators. i'd like to fit a single 120 and a dual 120 inside. I'll probably use corsair self contained loops so i don't need to deal with finding a spot for reservoir and pump. I'm fairly adept at case modification but would like to keep it to a minimum if possible.
not sure about a dual 120 but I know the Cooler Master Elite 130 will support a front 120 radiator. http://www.newegg.com/Product/Product.aspx?Item=N82E16811119286&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-PCPartPicker,%20LLC-_-na-_-na-_-na&cm_sp=&AID=10446076&PID=3938566&SID=
