chaoticjoy1 Distinguished Mar 14, 2008 49 0 18,540 Aug 4, 2008 #26 In the SPD tab at the bottom shows the memory's voltage:
T tjcinnamon Distinguished Mar 10, 2008 51 0 18,630 Aug 4, 2008 #27 These readings seem off. It says my max bandwidth is PC2-6400 (400MHz) Then it says my Model of RAM is CM2X1024-8500-C5D (which is 1066MHz), I have 4 dimms which is correct. Then at the bottom I am given 3 voltages JEDEC#1 JEDEC#2 EPP#1 --- the first column is blank 277MHz 400MHz 533MHz 4 5 5 4 5 5 4 5 5 13 18 15 15 22 22 2T 1.8V 1.8V 2.2V My stats from the memory tab are 533MHz 5:8 5-5-5-18 2T
chaoticjoy1 Distinguished Mar 14, 2008 49 0 18,540 Aug 4, 2008 #28 then it is 2.2v, and i dunno bout 400mhz thing
T tjcinnamon Distinguished Mar 10, 2008 51 0 18,630 Aug 4, 2008 #29 I'll try lowering and raising the voltage and I will see how that value changes. I'm running memtest right now. It went through all tests successfully and on the 2nd round of tests had 2 errors on test #5. Does that mean it's being over or underpowered?
T tjcinnamon Distinguished Mar 10, 2008 51 0 18,630 Aug 4, 2008 #30 I have my CPU timing and FSB set. If I am only changing the RAM timings then is the only voltage I need to change to accommodate the DDR voltage?
Zorg Splendid May 31, 2004 6,732 0 25,790 Aug 6, 2008 #31 tjcinnamon : I have my CPU timing and FSB set. If I am only changing the RAM timings then is the only voltage I need to change to accommodate the DDR voltage? Just set the voltage to the factory spec for the frequency you are running and leave it. I assume you are watching your temps with Real Temp. Next is to read Comp's Core 2 Quad and Duo Temperature Guide. Then use Prime95 Small FFTs to stress test your CPU and blend to test CPU and RAM. Be sure to watch your temps.
