Whats my system worth?
sramp17
4
First time posting here, but a long time reader. Just wondering what you think my system is worth. I have been itching for a new build so that is why I am asking.
Intel core i7 3770k
Corsair RAM 8GB at 1600mhz
Asus p8z77 v-pro
Dual GTX 680 in SLI
60 GB SSD for operating system
1TB HDD for programs and storage
NZXT Phantom case in white with blue lighting
Everything runs perfect and has never been over clocked. I planned to when i first bought my parts but never felt the need to do so. Side note is that one USB port on top of case is physically damaged. Aside from that it does not have a single flaw
the build is pretty great i think you can pull down $900 to $1200 off of it .. it should be worth that or a little less seeing that its used..you should be getting a good deal oof it though
this is what i would charge for a system like that, if it's in good condition.
cpu - $250
gpus - $400
motherboard - $100
ram - $60
ssd - $30 - $40
hdd - $40
case - $50
total = $940
you can always tell them that the two 680s are basically identical to dual gtx 770s. which they very much are. i believe the gtx 770 just has slightly faster memory than the 680 from what i recall?
