What's the best way to listen to Xbox One and PC sound through the same headset?
Vexiified
17
Like the title says, I want to be able to listen to my xbox and my pc sound simultaneously. I would also like to be able to still use my mic to talk in party chat on Xbox but I'm not even sure if that would be possible. If anyone knows how to do this please help. It's just really convenient to be able to listen to my pc and my xbox at the same time.
https://www.amazon.co.uk/HQ-Sources-Output-Manual-2-Port-Black/dp/B000XT8XHU/ref=sr_1_1?s=electronics&ie=UTF8&qid=1506512088&sr=1-1&keywords=audio+switch i found this but this one won't support the microphone
I think the only thing that will feet your needs is an actual audio mixer because switches don't allow simultaneous inputs to the output. On the other hand a mixer will allow that and also you'll be able to adjust the volume coming from both inputs.
And about the microphone well you just need to extend the cable to the microphone input on the Xbox
