[SOLVED] What's the difference between DIMM, UDIMM, SO-DIMM?
Dec 22, 2020
I'm planning on getting more ram for my pc, as I only have a single 8gb stick. I know that my current ram is DDR4 so I was obviously looking for the same type of ram, another 8gb, but I saw that it's also "DIMM" and i was looking around and found that there's not a lot of 8gb single stick ram for DIMM being sold. Is there a difference in if I use DIMM, UDIMM or SO-DIMM?
My PC is a prebuilt that I bought a few years ago when I didn't know better, it only has 2 ram slots and is currently using one of them for an 8gb stick.
Also, adding a single 8GB to the current one may not work.
RAM is only guaranteed to work in the set that are sold. Adding another may work, it may fail.
Reactions: PrimalSins
So then it's smarter to just buy 16gb in a set of two 8gb sticks and replace the old 8gb stick? But then does it matter if I get a UDIMM or DIMM or whatever?
There's so many different types of DIMM's though, like UDIMM and RDIMM and SO-DIMM, I don't know which one's better though. I found some info about the different ones being for different things like server hosting and stuff, but I'm just generally confused on which to look for.
You have a consumer system so you're technically using udimms (unbuffered dual inline memory module). These come in ecc and non-ecc variants. They also come in ecc buffered aka ecc registered modules (RDIMMs)--these are typically only for servers and workstations.
SODIMMs are for laptops because they are physically smaller (unbuffered dual small outline inline memory module). These are typically all non-ecc.
