The size is the difference here. The H110i v2 is a 240mm radiator and the H115i is a 280mm radiator. The increased size means larger fans which means better cooling performance. However, ensure your case can fit the cooler you choose.
MERGED QUESTION Question from Nathan2017 : "Case for one h115i watercooler and a h110i GT wc"
Nathan2017 :
Well guys, i only need the most cheaper case you guys can find that i can use these two wc, the h115i for i7 7700k, and the h110i GT for the gtx 1080ti (with nzxt g10)
Please help me guys! Thank you so much
the nerd 389 :
What other parts are in the build?
If you're planning to have an optical drive and several hard drives, this could get interesting. Not many cases support two 280 radiators and also have room for more than a couple of drives.
the nerd 389 :
Asus Prime Z270-A
Rog Strix Gtx 1080ti - i will buy when i have money..
16gb ddr4 3000mhz
EVGA SuperNOVA 1600 T2 220
1 or 2tb hdd
Cd/Dvd Bluray drive
