Hello there guys the last week I bought the next componentes:
1 motherboard AsRock B350-HDV
* Ryzen 2200g
* EVGA 450W BT supply
* 2x 4gb ram Patriot 2400Mhz
* 1tb Toshiba 7200 rpm
As you can see this didnt work because i needed the update before, so i tried now with an AMD APU-9700, that cpu should work fine in the MB but my surpirse it didnt work, I tried everything (even CMOS Clear). Everything was on the fans, cpu fan, but i couldnt get post.
Well my first thought was that the MB was damaged but I visit the AsRock webpage to check the RAM Compatibility.
But here I found two different categories:
Well here comes the interesting part the Memory QVL category has the next compatibility RAM:
As you can see my Patriot RAM is not among the compatible RAMS.
But in the Memory QVL (Raven Ridge):
Here my RAM is among the compatibility list.
I look for what Raven Ridge means and Ive found that referes to the Ryzen AMD CPU, so my question here.
Thats the reason why i couldnt post even with that cpu?
* Ryzen 2200g
