First, in a lighted fan the LIGHTS in the frame are completely separate electrically from the MOTOR of the fan. Their power sources and control systems are different, which is why there are two separate cables. By the way, most modern fans have LED lights, not LCD.
Two fans fail in a short time when new? NOT normal. It leaves me suspecting that the fan speed control system for them is mis-adjusted. You should tell us what mobo you have - maker and exact model - and in which mobo fan headers these fans are connected. All fans can stall if sent a signal to run too slow, so there is a minimum speed signal to send out to them. In general the system should NOT ever try to stop the fans. There are automated systems to monitor fans speed signals to detect a fan that sops and attempt to re-start it, but that may NOT work for ALL fans, especially in a multi-fan connection group. Sometimes people set fan control systems to run too slowly to eliminate noise, but SLOW fans mean POOR cooling - you can't have silence plus good cooling! With info on how there fans are connected and where, we can advise the best configuration settings.
