My PC boots up normally and has no problems when I'm not playing games, but 20-30 minutes after playing games the displays on both my monitors are filled up with white vertical lines, the sound loops, the pc stays ON and everything is still connected and then the computer becomes 100% unresponsive. If i try turn it back on the pc boots, the fans run and everything but the monitors don't connect to the gpu and my peripherals don't connect either?
I have tested the temps for the CPU and GPU and they are both well below too hot for any problem. (VRAM maybe?)
I did not make and system,software or hardware changes between my PC working and not working.
SPECS:
Msi-p67a-gd65
i5 2500k @ 4.2GHz
XFX 7970 black edition
8GB ddr3 ram
256gb sdd with OS on
1TB 3.5" black drive
(I had my 7970 oced to 1125/1575 for a month or two without problems until now, the card has never overheated.)
SPECS:
Msi-p67a-gd65
i5 2500k @ 4.2GHz
8GB ddr3 ram
C++:
