DMP file for those who need it https://drive.google.com/file/d/1Ljf_oIf0VHNR2IgCH3iDKyyghXCmcmll/view?usp=sharing
(all temperature referenced in the post are CPU, GPU is fine)
This problem has been strange, for the past 10 months I have been getting on and off WHEA_UNCORRECTABLE_ERROR crashes and strange PC temperatures. Before the issues began my computer idled at around 30-40c when gaming typically stayed at 45-65 range. But over these past months, when gaming the temperature rises to a constant 60-80 and 40-50c idle when playing games. So when I saw this jump I gave my computer a clean with an air duster, It didn't seem like I cleaned much but it worked like a charm. But it came back about a week later, so I cleaned again and it went away this cycle repeated for a month until the problem fixed itself. About 2 months later it came back (please note I clean outdoors, don't have a dusty computer area and room temp averages about 24c). This cycle repeated with short and "Long" respits until now...
I can no longer "clean" the problem. Temperatures idle 45-70 and while gaming 55-80 it's worse than ever.
The WHEA crash occurs after the computer has maintained a temperature of above 65c for more than 5 minutes, typically when a complex event (such as in ingame explosion or closing an application) occurs. After a crash does happen the computer is very hot; even when stating up it can peak up to 75c. Often causing another crash to occur. I don't understand the issue?
Some common thing that are not causing it:
I don't have OC
My CPU's voltage never changed from factory
As far as I know all drivers are good
My specs: https://ca.pcpartpicker.com/user/12wew/saved/9sRYJx
I hope I can find the answer here, thanks in advance guys!
P.s. I found some of my issues to be similar to
http://www.tomshardware.com/forum/id-3053254/whea-uncorrectable-error-high-idle-70c-load-100c-temps-4790k.html?xtor=EREC-8889
but I have water cooling and I see no issues there...
I don't have OC
