WHEA UNCORRECTABLE ERROR.....I am so tired of trying to figure this out.....please help.......thermal issue?
Dutchoperative
105
CPU: AMD FX 6300
CPU Cooler: Coolermaster Hyper 212 Evo
MOBO: Asus M5A99FX r2.0
GPU: Sapphire r9 280X
RAM: 2X4GB Crucial Ballistix
PSU: Seasonic S12II 620W
HDD: Western Digital Blue 1TB
CASE: Corsair 200r
CASEFANS: Corsair AF120
NO Overclock
Okay, so I used to get this particular crash every once in a while when I first built my computer and I have heard that it is often associated with thermal issues. I used to BSOD after several hours of gaming fairly frequently. When I bought my case, one of the fans was faulty and I had to spin it manually to get it started. Initially, I would start the fan manually and then put the side panel back on. However, I grew tired of having to remove and replace the side panel every time I started my computer and eventually just left the side panel off altogether. Well, after I did that, my computer did not crash for several months. Recently, I bought a new set of Corsair AF120 case fans and put my side panel back on permanently. For a couple of weeks everything worked perfectly fine, but just a few minutes ago, after several hours of Fallout New Vegas, my computer blue screens and I get the dreaded WHEA UNCORRECTABLE ERROR. Could this be a result of inadequate ventilation? I have one intake fan on the front of the case and one exhaust on the rear. My CPU fan is facing upward and is exhausting out of the top of the case. From my understanding, this is a fairly common configuration so I have a hard time believing that this could be the issues......I have ran SlimDrivers and Malwarebytes and according to these programs my drivers are up-to-date and no malware was detected....Any suggestions would be EXTREMELY appreciated....
Here is the Crash Dump Analysis from WhoCrashed
crash dump file: C:\Windows\Minidump\041215-15880-01.dmp
This was probably caused by the following module: hal.dll (hal+0x12A3B)
Bugcheck code: 0x124 (0x0, 0xFFFFFA8007E58028, 0xBC800000, 0x135)
Error: WHEA_UNCORRECTABLE_ERROR
file path: C:\Windows\system32\hal.dll
product: Microsoft® Windows® Operating System
company: Microsoft Corporation
description: Hardware Abstraction Layer DLL
Bug check description: This bug check indicates that a fatal hardware error has occurred. This bug check uses the error data that is provided by the Windows Hardware Error Architecture (WHEA).
This is likely to be caused by a hardware problem problem. This problem might be caused by a thermal issue.
The crash took place in a standard Microsoft module. Your system configuration may be incorrect. Possibly this problem is caused by another driver on your system that cannot be identified at this time.
Yeah, I tried to install the drivers from the original disk but I got the same result. I have left the CPU at stock clock speed by the way. I just wish I could isolate the cause of these crashes.....it just seems to be too coincidental that I go several months without a crash but a week after I put the side panel back on, I get the same crash I was getting months ago....
I was getting the WHEA UNCORRECTABLE ERROR BSOD a few months ago once a week or so after gaming for a few hours. After taking the side panel off, I went three months or so without a crash. Now, I put new fans in, put the side panel back on and all of the sudden, a week later it crashes.
On earlier versions of Windows this error would make it blink restart, you wouldn't even get a warning.
If this was my computer I would have the cpu fan vent out the back right at the exit fan, and I would review the settings for your cpu voltage and clock rate. Power is dipping or something is getting too hot on the motherboard. Don't be confident in the ASUS stock settings.
Think of it this way, rocking an AMD 990FX is like the wild west, it's up to you to test and validate what your complete system can do, thats how you saved the money going AMD and enthusiast parts.
