Yes.. I did post a thread about this yesterday and i marked an answer correct before i checked it actually worked.
I left the computer to turn off with no charge after i had done powercfg -h on and set it to hibernate in the power controls.
Once i came back to it I plugged the charger in and it didn't work.. It did boot up normally and took me to the password screen but none of the stuff before it turned off was there.
I'm sure there's some sort of easy fix other than "open this and look in that and take the screws of this and that"
I don't want to end in a bigger problem than i had originally started with.
