When I hold down a key for a bit it will have a delay to stop
Brandawg451
As you see in the title if I hold down a key then let go it will repeat a little bit longer. This is a big problem in gaming and I have a laptop connected to a usb via keyboard and both do the same thing please help. Windows 10 was the only spot I could find to but this sorry
Hi,
Have you tried adjusting the keyboard settings inside Windows?
- Right click on the Start button and select Control Panel then select Keyboard.
- Once opened, move the slider under Character repeat for "Repeat Delay" and Repeat rate" until it match your liking.
- Click Apply and OK once done then test it again.
If these doesn't work try to uninstall/reinstall the keyboard driver.
- Go to Device Manager and uninstall the keyboard driver.
- Reboot your laptop once uninstalled and it should reinstall the driver automatically.
- After the reboot do test it again and see if the same problem will persist or not.
Also do disable sticky keys from Control Panel.
- Go to Ease of Access and click on Make the keyboard easier to use.
- Under Make it easier to type, remove the check on Turn on Sticky Keys.
- Click Apply and OK then test it again.
Latest posts
