Question when i oc my monitor it will be blurry and pixelated
11
Hello Everyone,
When i try to Overclock my Monitor which it's "Samsung SAM0632 -SMB 1930N native resolution "1360x768" 60 hz " from 66 hz to 75 " it will be blurry and pixelated
any one can fix this to me please i want to play Cs:go and other games with smooth movement .
Thank you so much guys i'm waiting for answer !
my specs are:
i5 4690 k 3.5 ghz
8gb ram
gtx 1050 ti gaming x
Windows update last and last updated drivers (sry for bad englihs)
and in any game and the destkop too looks like blurry and pixelated
Update your post to include full system hardware specs and OS.
What other games?
More information is needed.
Hello Everyone,
When i try to Overclock my Monitor which it's "Samsung B1930n native resoulition "1360x768" 60 hz " from 66 hz to 75 " it will be blurry and pixelated
my specs are:
i5 4690 k 3.5 ghz
8gb ram
So, just to clarify:
When not overclocked, the display is clear and sharp but movement is jerky - not fast and smooth.
When overclocked movement is fast and smooth but also becomes blurry and pixelated.
Correct?
Also - are you overclocking the gtx1050 ti gaming x?
If so, stop overclocking both gpu and monitor.
The system should have smooth performance and a clear displays - if not, then something else may be amiss.
Then incrementally overclock just the gpu while leaving the monitor not overclocked.
Does the problem reoccur at some point?
Reactions: l7ajbrahim
Correct?
Well when i oc my monitor it will be movement is fast and smooth but also becomes blurry and pixelated. that is correct and i'm not overcloking my GPU .
Per @rgd1101's post - have you checked the monitor's specs and the supported frequencies and resolutions?
What happens (happened?) when you started without any monitor overclocking and worked "upwards" through the monitor's available/supported frequencies and resolutions?
Also, consider some OC testing via the GPU while leaving the monitor's settings alone.
Remember: just change one thing at a time and be methodical.
Well , i'm not overclocking the gpu and monitor
i try to overclock the monitor from 61 hz to 75 hz still blurry and pixaled .
