[SOLVED] When PC is turned on RED CPU light flashes on for a few milliseconds then shuts down entirely. Can't seem to fix. HALP!
Feb 9, 2021
I am using the following parts
AMD RYZEN 5 3600 6-Core 3.6 GHz (4.2 GHz Max Boost) Socket AM4 65W 100-100000031BOX Desktop Processor
https://www.newegg.com/amd-ryzen-5-... 5 3600-_-19-113-569-_-Product&quicklink=true
MSI B450 TOMAHAWK MAX AM4 AMD B450 SATA 6Gb/s ATX AMD Motherboard
https://www.newegg.com/msi-b450-tom...erboard-_-13-144-267-_-Product&quicklink=true
CORSAIR VS Series VS600 600W 80 PLUS Certified Non-Modular ATX Power Supply, CP-9020224-NA
https://www.newegg.com/corsair-vs-s...ply&cm_re=power_supply-_-17-139-266-_-Product
MSI GeForce GT 1030 DirectX 12 GT 1030 2GD4 LP OC 2GB 64-Bit DDR4 PCI Express 3.0 x16 (Uses x4) HDCP Ready Low Profile Video Card
https://www.newegg.com/msi-geforce-...rd ddr4-_-14-137-318-_-Product&quicklink=true
Lenovo ram ddr4 8GB desktop Gaming memory 2666MHz Interface Type 288pin 1.2V memoria rams ddr 4 for PC
https://www.newegg.com/lenovo-8gb-2...dr4&cm_re=RAM_ddr4-_-9SIATTBDDE3695-_-Product
When turning on pc cpu light flashes for a millisecond and everything shuts down, I double-checked the connection to the power supply and that the reset and on switch has been wired properly.
One of the common causes of short circuits in a brand new assembly is that one or more case stand-offs is in the wrong position, OR that none ever were used at all. See my post of Dec 12/20 in this thread
https://forums.tomshardware.com/thr...sult-in-a-lose-of-data.3670519/#post-22107308
It was written for someone who planned to move his system to a new case, but it applies to your situation as you mounted everything in a new case. If you have any reason to suspect the stand-off location is involved, I suggest you unscrew all the screws (often nine) that hold the mobo in the case, and remove it carefully. Then study closely whether every one...
It was written for someone who planned to move his system to a new case, but it applies to your situation as you mounted everything in a new case. If you have any reason to suspect the stand-off location is involved, I suggest you unscrew all the screws (often nine) that hold the mobo in the case, and remove it carefully. Then study closely whether every one of the stand-offs is exactly where a mobo mounting hole is.
