I just got my Rosewill challenger from UPS guy( 40$ with promo code), great case for a total beginner noob like me. The are broken parts though: the screws( those plastic ones that if you apply pressure they pop in holes) for the front panel are broken, but can be easily glued. I took the front panel off and the plastic mouth-like screws were stuck in the holes, making it very easy for the panel to open, even if its closed on the right side.
Im planning on buying an i5 3750k, GEFORCE 670, basically mid-high gaming pc: it's a great case for beginner, but since I never built a pc and the parts are expensive should I get a better case??
If I glue them back can I have problems when the case is built, or am I better of RMAing it right away from Newegg? This is the first hw component I bought, never opened a case In my life lol
