When turning volume down to 0 i hear POP sound for my headphones
Hello rihardslusis2
Can you please confirm if it is the popping sound or the default 'ding' sound that comes up every time you change the volume level?
Meanwhile, please ensure that it's the master volume you're reducing to zero and not the volume for any other app. You can right-click the speaker icon from the notification area, click Open Volume Mixer, and make the appropriate adjustments from there.
Hope this helps.
Cheers!!
just tested and its not the default 'ding' sound and i only hear the popping sound when i put my speaker volume to 0 so i think it has to do with my headphones
Hello again
In that case, can you please try using a different headphone if possible, or connecting this one to a different computer and see the results?
Cheers!! :)
tried using diffrent headphones still hear that sound and on other devices it doesnt happen so i think its my pc
