[SOLVED] Where do you plug in chassis fan? PSU or Motherboard?
Dec 29, 2022
17
I have these 4x12cm fans, 3 on front-intake, 1 exhaust. All of them are molex connector which directly comes from PSU and I assume they will run on max curve all the time, right?
So, my concern is should I use these fans or look for another fans that is PWM connector from the motherboard?
(note: I'll be using this PC for gaming and some programming)
Reactions: bbyaga455
Can you tell me what is that 3 pin header on the bottom left called "chassis"? Is it related to fan system?
Taken from Asus A520M-K motherboard.
