Question where does fan hub connect on my motherboard?
Mar 31, 2021
5
I've got the masterfan hub to connect all 6 of my masterfan mf120r fans (just for power the argb is connected to the controllers) and it's saying to connect to cpu fan header but is that where it goes? or does it go somewhere else?
Eximo
Ambassador
If you want the fans speed to be controlled by the CPU temperature, yes. Though fancy motherboards will have fully configurable fan headers and you can set fan curves and base them on other temperatures.
