i already cleaned the dust out of pc. please help the noise is rlly bothering me
yes i cleaned everythingDid you clean your gpu as well?
Also in the bios you should be able to regulate the rpm of your case and cpu fans
but the pc overall is running at cool temperatures only the noise.. its killing meDid you clean your gpu as well?
first we must determine what mobo your pc has, so that we can use the manual
Download this software and let it run, then tell us what mobo you have
https://www.ccleaner.com/speccy/download
also be sure no wires are touching your fans
ok thanks! can you tell me how the rpms should be?go to the bios
Go to the configuration tab
then Fan control & real time monitoring
Lower the rpm's there, and see if it helps
you can always revert if it doens't help
oky thanks for your help, will try itno idea tbh, I'd lower them in 100 rpm increments
