Where to connect fans RGB?
Sep 21, 2018
8
My case have 3 fans ANTEC DF500 8 want to connect those fans RGB to my motherboard .GIGABYTE AROUS ELITE .Which has 12v rgbw header which is 5 pin and other 5v 2x digital RGB headers .How to sync my fans RGB to gigabyte fussion?
Is this your motherboard? If so, you can have the fans daisy chained and connected to one of the 4 pin RGB connector on your board(located between D_LED and 5 pin ARGB header).
You will need to download the app from Gigabyte's support site. You're still going to need 3 fan headers for the 3 fans(apart from the CPU fan).
The case comes with an RGB controller at the back of the case and it's functionality is accessible from the front panel but it'll not be sync'd with the app.
.I don't have the motherboard but just curious how to connect rgbs when i bring one.
Yes thats the mobo I was looking.
It has 3pin d_led 5v and 5 pins rgbw 12v connecter.which connecter are you talking about.
It has 3 fan headers.
