Question Where to connect the ARGB Input cable?
OMGPenguins
31
You connect that chain to a molex connector from PSU.
Take more pictures of where the wires terminate.
Your motherboard lacks an ARGB header even though your board has an RGB header and no, ARGB and RGB aren't cross-compatible with each other since they operate on two different standards.
You also picked one of the worst cases, since the front is blocked off of any ventilation for the fans to draw in fresh, cooler ambient air.
View: https://imgur.com/a/3rXAfLx
First 2 are from the case and last 3 from the PSU
