I have a question about where in a new system build to make cuts if you need to lower the cost of the build . For example I am hoping to build a new PC with the following parts. CPU: Ryzen 5 1600, Motherboard: MSI Tomahawk, RAM: G.Skill DDR4 3000mhz 16GB, SanDisk 240 GB SSD.
I will add an RX 480 and an EVGA 600 watt power supply I already own. If I wanted to lower the cost of the build where would I make sacrifices first that would make the least impact on the performance? Drop down to a 1500x? Lower clocked RAM? 8GB of RAM instead of 16GB? Just not sure which of those would make the least impact. I am asking because with those parts I am about $50 over budget.
Also if anyone has a suggestion as to what parts would go well with an RX 480 4gb please let me know. I have a feeling that due to current GPU prices I will be using it for awhile.
