Where to mount radiator on Corsair Obsidian Series 750D case
IronPickle
Commendable
Jul 6, 2016
12
I recently purchased an EVGA CLC 280 Liquid / Water CPU Cooler to replace the stock Intel heat sink that came with my processor. My case appears to have room for the radiator on the top as an exhaust and on the front as an intake. There are already two 140mm fans on the front of the case so they would have to be moved if I want to put the radiator there. I should also note that I have an EVGA GeForce GTX 1080 Ti SC Black Edition graphics card installed. This would sit below the radiator if I mounted the radiator on the top of the case. It would be easier to install the radiator on the top of my case, however, I'm worried that the GPU is going to throw so much heat on the radiator that it won't cool the processor any better than the stock cooler did. Please advise
Is your GPU an open fan type or is it a blower?
Open. (trio)
