Which adapters will I need to connect my HDMI cable from my laptop to my TV?
alliemk
I stupidly bought an HDMI cable without realizing that my laptop doesn't have a hole to match the cord, and I'm pretty sure my TV doesn't either. I am assuming this will require adapters of some sort on both ends, but I'm not sure exactly what I'll need.
This product will ONLY work if you have a video-out function. I suspect it's not common but not sure:
http://www.monoprice.com/Product?c_id=104&cp_id=10430&cs_id=1043012&p_id=2509&seq=1&format=2
VGA to S-VIDEO: http://www.monoprice.com/Product?c_id=101&cp_id=10114&cs_id=1011407&p_id=4724&seq=1&format=2
VGA to Component (not the best customer feedback though): http://www.monoprice.com/Product?c_id=101&cp_id=10114&cs_id=1011407&p_id=8668&seq=1&format=2
*You'd also have to apply the proper video output which for a CRT is likely "480i" under the TV section but I've never tried this. It will have 720x480 resolution though that doesn't exactly match a monitor or HDTV because the pixels aren't space the same (more sideways than up and...
You will probably need a Mini DisplayPort cable. However, some TVs don't have these.
Therefore, what you will need is a Mini DisplayPort to VGA cable.
If your TV doesn't have a VGA port, try a Mini DisplayPort to HDMI cable.
Just check to see if your laptop has a Mini DisplayPort port first. :lol:
If I understand correctly you have an older TV with only Component or Composite inputs and a laptop with only VGA output?
If so you need a "VGA to composite" or "VGA to component" active converter.
(Not sure why a laptop would have mini DP output but not HDMI)
*You'd also have to apply the proper video output which for a CRT is likely "480i" under the TV section but I've never tried this. It will have 720x480 resolution though that doesn't exactly match a monitor or HDTV because the pixels aren't space the same (more sideways than up and down). This can cause video to look stretched.
