Question which ARGB hub should i get ?
Feb 12, 2025
my motherboard lacks a ARGB header, i’d like to buy a argb hub to combat this issue, the cheaper the better but if possible i’d like to be able to control it through my pc, if that isn’t possible the it’s fine
Where are you located? What is your budget to purchase an ARGB hub? Preferred site for purchase? Please mention all ARGB gear in your build as well as the make and model of your motherboard.
i live in the UAE, i’ll be using amazon , i don’t know how to check what model my motherboard is but a friend told me that it lacks argb, all i know it’s a older prime motherboard , all my fans are GALAX Revolution i think and i have 3 fury ram sticks, my budget it’s around 100 aed which is around 30 dollars, excuse me for my lack of knowledge but this pc is a prebuilt
