Build Advice Which build will perform better, an i5 or a Ryzen 5 ?
BasMaster
12
HI every one.
I come with to you with my concern.
I can't make a decision on my new build. As going thru all specifications etc. it is hard to say witch build will be better.
CaseCORSAIR 175R RGB MID TOWER GAMING CASE
Processor (CPU)Intel® Core™ i5 10-Core Processor i5-13400F (Up to 4.6GHz) 20MB Cache
MotherboardASUS® PRIME B760-PLUS D4 (LGA1700, PCIe5.0, USB 3.2)
Memory (RAM)16GB PCS PRO DDR4 3200MHz (1 x 16GB)
Graphics Card8GB AMD RADEON™ RX 6600 - HDMI, DP - DX® 12
Graphics Card Support BracketPCS GRAPHICS CARD SUPPORT BRACKET
1st M.2 SSD Drive250GB KINGSTON NV2 NVMe PCIe SSD (3000MB/R, 1500MB/W)
DVD/BLU-RAY DriveNOT REQUIRED
Power SupplyCORSAIR 650W CV SERIES™ CV-650 POWER SUPPLY
Processor CoolingDeepCool AK400 Performance CPU Cooler
or
Processor (CPU)AMD Ryzen 5 5600X Six Core CPU (3.7GHz-4.6GHz/35MB CACHE/AM4)
MotherboardGIGABYTE B550 GAMING X V2 : DDR4, USB 3.2 - ARGB Ready
This build going thru pc shop so I don't want to ask them as they will look ( most of times) on profit not on what is the best for me.
I will be very pleased if anyone can help with advise.
SSD drive is not relevant at all.
you won't notice the difference day to day with either CPU.
they are so close in performance it's not worth worrying about. the only way you'll notice the difference is if you spend all your time benchmarking and stat watching. otherwise flip a coin and know either one will be a great system.
Reactions: BasMaster
Processors are comparable at the given price point.
I would rate the i5-13400 a bit better because if the slightly better single thread performance that is most important for gaming:
For a trivial price difference, I would buy the i5-13400 with included graphics.
If you should ever have a gpu issue, integrated can bail you out.
Both processors come with an adequate cpu cooler.
The AK400 is only marginally better.
If you are going to buy an aftermarket cooler, buy a good one.
It is a mistake to buy a single 16gb ram stick.
Processors run faster with a 2 stick kit of 2 x 8.
Lastly, do not buy a cheap psu. That Corsair is considered as tier C, low end.
It has only a 3 year warranty.
You really want a psu with at least a 5 year warranty or preferably 7-10 years.
Look at Seasonic focus or corsair RM x.
And, I would buy 750w or more.
Either processor can run a stronger future gpu upgrade.
Pretty big sample of benches shows the 13400 to be 15% faster in apps and about 5-6% better in games if there is no slow down from the GPU.
It's not a huge difference but if you have to pay for them get the one that gives you more.
