Which cable to use for 144hz monitor
DannersUK
I have an AOC 2460pf monitor and MSI GTX 970 gfx card.
I currently have a DVI-D SINGLE link cable so can only run my display at 60hz
Which is the best cable for running at 144hz. I've heard both DVI-D Dual link and Display port cables can both do this.
Which would be the best option. I will be using this for gaming so will once out perform the other?
As far as image quality is concerned, you can use whichever (DVI-DL or DP), there won't be any noticeable differences between the two at 1080p/144Hz.
If it matters to you, DP carries both video and audio signals and has better support for 3D video (for 3D monitors). Since you probably won't use the monitor's crappy speakers and since the monitor doesn't have 3D support, you can then use either without one outperforming the other.
Note also that the AOC G2460pf has AMD FreeSync support, and it requires a DP connection for it to be enabled (DVI-D doesn't). So, since you are using an Nvidia GPU, it would still not matter whether your use DP or DVI-D.
If you do, however, use an AMD GPU in the future, you should use DP to enable FreeSync.
Also to add when it comes to DisplayPort cables, just the name isn't enough to guarantee you the features the interface promises. Just like categorized HDMI high speed cables, DisplayPort also follows a standard for extreme bandwidths. If you do go buy one, do the research.
https://www.displayport.org/cables/how-to-choose-a-displayport-cable-and-not-get-a-bad-one/
There are DP cables only rated for 1080p 60Hz so read the description and possibly certification's if available. Many dud cables out there (They'll work but good chance not at full specification) so be careful and stick to known brands like Startech and Accell that are Vesa certified.
https://www.displayport.org/products-database/?products_category%5b%5d=cables-connectors&products_manufacturer=
Check the small box next to cable in the upper field and then search, they'll list you certified brands.
Edit: High bitrate DisplayPort cables supplied with monitors are certified. It's buying them separately is when need to be careful.
