Which card will fit in my cooler master elite 130?
I already have that card..i am going to install that in a couple of weeks..
I know the card's length and height but i am not sure about the width..Will it fit width wise or will i face any problem in closing the case? I have checked the card's specs on the website and in the Slot Size it says triple slot.. I am giving the link of my cabinet's picture and i think the cabinet support two slots i am not sure..
This is specs given on zotac's website for the product
PRODUCT SPECIFICATIONS
Specifications
GPU GeForce® GTX 970
CUDA cores 1664
Video Memory 4GB GDDR5
Memory Bus 256-bit
Engine Clock Base: 1203 MHz
Boost: 1355 MHz
Memory Clock 7200 MHz
PCI Express 3.0
Display Outputs 3 x DisplayPort 1.2: 4K @ 60Hz
HDMI 2.0: 4K @60 Hz
DL-DVI: 2560x1600
HDCP Support Yes
Multi Display Capability Quad Display
Recommended Power Supply 500W
Power Consumption 176W
Power Input 2 x 8-pin
DirectX 12 API feature level 12_1
OpenGL 4.5
Cooling 90mm Triple Fan
Slot Size Triple slot
SLI 2-way
Supported OS Windows 10 / 8 / 7 / Vista
Card Length 299.97mm x 141.22mm
Accessories DVI-to-VGA Adapter
Dual 6-pin to 8-pin PCIe adapter
Driver Disk
User Manual
Specifications
CUDA cores 1664
Memory Bus 256-bit
Boost: 1355 MHz
PCI Express 3.0
HDMI 2.0: 4K @60 Hz
DL-DVI: 2560x1600
HDCP Support Yes
OpenGL 4.5
SLI 2-way
Driver Disk
User Manual
Specifications
CUDA cores 1664
Memory Bus 256-bit
Boost: 1355 MHz
PCI Express 3.0
HDMI 2.0: 4K @60 Hz
DL-DVI: 2560x1600
HDCP Support Yes
OpenGL 4.5
SLI 2-way
Driver Disk
User Manual
The case will give you around 2.5 inches for the width of the graphics card. From the pics of the graphics card, it looks like a double slot and not triple slot as stated in the specs. Can't find an actual dimension for the width. You might contact Zotac support and see if they can give that to you.
