Having trouble deciding on case for first-time build. Looking for a relatively inexpensive case. Prefer quiet windowless case. It will be in a bedroom, so no garish LED lights. Want at least 2 front USB points (ideally 3.0), headphone and microphone ports.
Some system specs:
CPU: i5-6500
GPU: Nvidia EVGA GTX 950 FTW
HD: 1 SSD, 1 (maybe 2) platter HD
Motherboard: Likely ATX
RAM: 2 sticksx4 GB (maybe later 4 sticks)
Carbide 100R Silent Edition is cheapest. I think I like this case the best (external fan control, closed top, silent foam). But I'm worried about whether it has enough cooling or cable management space.
Carbide 200R is only about $5 more. I've heard good things about this case. I doesn't seem like a bad choice, but I'm worried stuff (dust, spilled drinks) could fall through the mesh top. Also, like being able to rest stuff (like external dvd drives) on top of computer case. Don't know if that would be a great idea on a mesh top case like the 200R. Also maybe more noise than other options?
Define R4 is most expensive (maybe at least $20 more?) and heaviest. I like the "moduvent" idea, but I'm worried the swing door could eventually break. Also, the reviews that I read don't make it seem that much quieter than other cases (but maybe I'm reading the wrong reviews).
Other case recommendations are also appreciated. Need to buy soon (ideally tonight), so quick responses appreciated. Thanks.
Some system specs:
CPU: i5-6500
