Which cooler for FX 6300 overclock?
Nick Powell
25
I am so confused over which cooler is the best to buy with a combination of price and quality. It seems a lot of people are split between different coolers so any advice for this build on which cooler I should buy (max $120) would be much appreciated!
AMD FX 6300 (going to overclock)
ASRock Extreme 3 Motherboard
Sapphire R9 280x Vapor GPU
Kingston 8GB RAM
2x 500GB WD HDD's
550W Thermaltake PSU
Thanks in advance!
From almost all of the forums I have read there simply isn't that much of a performance boost which justifies the price of an 8320 or 8350. People I have talked to recommend I just OC my current cpu with a good quality cooler which will almost (or will) match those cpu's. Feel free to tell me if it is different!
