N nhelweg Commendable Dec 20, 2016 16 0 1,510 Feb 5, 2017 #1 The Dark Rock TF by Be Quiet or the Noctua NH-C14S? Or is there any other cooler I should consider? The max height of the cooler has to be 156 mm (that's why I chose these 2) and I've got low ram, so no worries there. Thanks in advance.
Dark Lord of Tech Retired Moderator Aug 18, 2009 128,819 1,873 159,590 Feb 5, 2017 Solution #2 Both will perform equally , slight edge to Noctua. Upvote 0 Downvote Solution
N nhelweg Commendable Dec 20, 2016 16 0 1,510 Feb 5, 2017 #3 Both will perform equally , slight edge to Noctua. Thanks! Upvote 0 Downvote
