Which CPU cooler is a better overall CPU cooler among Deepcool Gammaxx GT and Cooler Master Hyper 212 Led Turbo Edition? Both are 120mm air coolers.
Basically same unit with some minor differences like fan curve and noise modulation. GT version is slightly better. Theres the RGB thing ofcourse.By the way, as you linked a video that's a comparison between Hyper 212 led and Gammaxx 400, what's the difference between Deepcool Gammaxx 400 and Gammaxx GT? Only RGB?
Yet there are possibilities of slight difference and I'm focusing on that little difference. I've heard from one of my friends that Deepcool Gammaxx GT is slightly better in terms of performance, ram clearance, height clearance and aesthetics . Is that true? What makes him say that?They will both give you around the same ballpark of performance, they belong to the same category...
CPU Cooler Performance Tier List
Last edited 2024.07.14 Cooler performance varies depending on the system. This list ranks coolers using generalized cooling performance from available benchmark results. Quality, aesthetics, acoustics, and ease of installation aren't accounted for. This is not a list of recommendations. A low tie...linustechtips.com
The GAMAXX does outperform the Hyper in some benches, but the difference is so miniscule that it doesn't matter much. But if that gives you mental satisfaction then you should go for it...Yet there are possibilities of slight difference and I'm focusing on that little difference. I've heard from one of my friends that Deepcool Gammaxx GT is slightly better in terms of performance, ram clearance, height clearance and aesthetics . Is that true? What makes him say that?
By the way, as you linked a video that's a comparison between Hyper 212 led and Gammaxx 400, what's the difference between Deepcool Gammaxx 400 and Gammaxx GT? Only RGB?The GAMAXX does outperform the Hyper in some benches, but the difference is so miniscule that it doesn't matter much. But if that gives you mental satisfaction then you should go for it...
View: https://www.youtube.com/watch?v=7tCm7HnzPi0
