which cpu water coolant is better ?
Tranzers
19
Hi guys!
Recently i saw 3 kind of water cpu cooler on the online purchase site but i don't know which 1 is better among these 3
1. Deepcool MAELSTROM 240T CPU Water Cooling
2. ID-Cooling FROSTFLOW-240L CPU Cooler
3.Raijintek Triton 240 Blue Liquid CPU Cooler
The price between the choice 1 and choices 2 is almost the same but the 3rd choose is slight expensive~ I'm not sure which kind should i have it ....
Not saying these are particularly bad, but when it comes to Water Cooling for your CPU, you should get something on the more expensive side, such as the Corsair H100i, yes, this is definitely more expensive than these 3, but it is one of the most recommended CPU Water Cooling Systems for this.
Also, what CPU do you have? as if it is a locked CPU, an Air Cooling system would be much better, and much cheaper.
My rig AMD Fx8350 + Strix R9-390x ~
I have change the default cpu cooler to deepcool ice edge mini the cooling effect is not really working dou ~
I'm not sure because i'm using old tower gaming casing or wat but i have pre-ordered a Corsair cp03 casing ~ because my casing air ventilation is not good enough ~ I always have to open the side case for the air ventilation if not my cpu and my gpu temperature is quite high ~ besides i dont think i will be able to afford Corsair H100i because this retailed price is almost 2-3 times of both of my 1st and 2nd choices
