Just a quick update for any future readers. Ive been using this cooler for about 2 weeks now and like i previously said, i have the fan facing down and exhausting out the top of the case. The temps have been fine and the cooler has remained quiet. When playing on a game like BF4, the fan never exceeds 50%. (If you was using this on an intel socket the fan would most likely be a lot more quieter.)
Anyway, my rig now has 3 case fans: 2 Intake 1 Top Exhaust so the CPU cooler is kinda running in a push/pull configuration. If you are in the same situation as me then i would definetly recomend buying 2 Corsair fans. I got the 2 pack of the red AF fans because my case already came with 1 static pressure fan which i lowered so it is pushing air through the hard drive cage. I put an AF fan at the front and 1 on top. When gaming i raise them to 50% and 40% whilst web browsing. They arent silent but they are quiet enough for me. Once again i would recomend having the case fans at 50% because it gives more cool air to the CPU cooler and because the fan is facing down you need the fans running reasonably fast for cool air to get to the CPU fan.
To sum up, i am happy with the cooling performance of this cooler but if you are thinking about buying the arctic freezer Pro Rev 2 7 cooler for an AMD CPU, i would not because of how you are limited to the mounting options of this cooler and to maximize airflow, you would have to buy more fans for your case and have the fans spin a bit faster. With the 15£ spent of the fans you could get a hyper 212 evo or something like that.
