which fan speed is best
Huntsman5978
29
so i have 2 choices to have fan speed at 20% when its under 60celcius and then it goes up to 40%
and the other is so the fan is at 0% when the gpu is under 60 celcius and then goes to 40% so which of theese are better
There is no 'better' choice per se, but I'd suggest running the 20% profile as a zero fan profile is only going to get the GPU to heat up faster and hit the 60° threshold anyway.
